Brief Description: Rivet leading edge, route stall warning wiring
Finished riveting the left leading edge. Mounted leading edge to the main spar assembly. Grommet bushing added to ribs for routing the Stall Warning wiring. Set up the right leading edge for riveting. Riveted the front two rivets on the top and bottom sides of the Right leading edge assembly.
Left leading edge mounted back onto the main spar assembly
Routing wire for Stall Warning device. You can see the wire passing through the next rib
