Brief Description: Access panel and doubler ring deburing / dimpling
Received the replacement wire/shepards crook for the fuel sending devise that previously broke. Bent up the linkage assembly. Debured the doubler ring for the access panel. Cut, debured, and bent up the anti-obstruction rail for the access panel. Drilled the flop tube holes in the front mounting brackets.
