Brief Description: Building the fuel sending devise linkage
Measure/fit and bend linkage for fuel sending devise. I bent one of the 90 degree turns the wrong direction and as you can see by the unit on the paper, the smal .68 turn is broken off. I'll have to order another linkage wire or improvise with a wire from Home Depot. ( Van's will sell the shepards crook wire, 5.00)
I also ordered the two flop tube assemblies for inverted flight.
one fully assembled linkage broke on the other tank
