Wesleys Web Site
Date:  4-16-2016
Number of Hours:  8.00
Manual Reference:  Left Elevator
Brief Description:  Left elevator assembly
Rivet the electronic trim system to the access door. Rivet nut plate hardware to access door. Rivet trim assembly.
Rivet spar assembly for elevator
Rivet root rib to spar with flush rivets then rivet elevator horn assembly
Bend elevator trim area and bend both sides fo the elevator trim tab piece
face view of the elevator horn
backside of the Elevator horn / root spar
bend section on the Elevatory trim
