Brief Description: Fabricated and Installed Rudder Stops
Fabricated left and right rudder stops per plans. I did not make the final angle cut for the rudders until I clecoed in place and measured the rudder skin to elevator trailing edge distance of 46-1/8". Angle is perfect and cable clears the stop nicely. Part was primed after the picture was taken. I will riven the stops on as the next step.
