Spent alot of time rerouting wiring and bundling wires for the avionics. Wound up removing the plastic conduit under the center access panel and bundling the wiring together. Tight ift as it exits the right side. The bundle is at least 1" in diameter. Used electrical tape to protect against chafing as the wires go up the firewall.
Added an adel clamp, picture below left most plate nut to secure the heavy wiring for the EMS and the three shielded strobe wires that connect together on the terminal block.
