Brief Description: Elevator push pull tube allignment
Bolted the two push tubes to the elevator bell crank and checked to make sure the bellcrank holes were level. Worked out perfect without any additional changes reqyured, The plans are very accurate on the pushtube lengths. The elevator moves freely and does not bind at the control stick, however I will need to adjust the elevator down stop as there is not enough down action. Looking at the plans there is no call out for the angle of the control stick. Looking at the plans there is a slight forward tilt of the sticks with the elevator in the neutral position. This can be adjusted later after the seats and panel are in. For now the adjustment looks good.
