Toms RV9-A project
Date:  3-9-2013
Brief Description:  Mounted Skyview Engine Monitor Module
Ran angle from the firewall to the intermediate bulkhead and installed platenuts for the Skyview Engine Module. All modules will be installed face down so that if I need to access or remove any module I will be able to unscrew from underneath the avionics panel.
Next steps will be to drill a hole through the firewall for the engine monitoring cables. I will have two holes through the firewall. One for the engine monitoring wiring and a second for the #6 main cable from the battery to the VP-X.
Engine Monitor with Cables laid out
Close up of Engine Monitor Module
Close up of rear shelf angle
