Decided that I would mount the Vertical Power VP-X unit in the center between the firewall and intermidiate bulkhead. Riveted angles and installed platenuts and mounted bottom up. I am installing all modules facing down so that when the top skin is riveted It will be easier to remove the unit for service if necessary.
