Brief Description: Oil Pressure line support and engine electric
Installed platenuts and secured the Oil Pressure sensor hose to the mainfold. Got my wire crimper in the mail yesterday so I crimped and installed the Primary, Secondary Alternator wires and the Starter wire.
Spent some time reviewing routing and materials for the Dynon Map sensor. Here is my materials list for order 1) Teflon Stainless Braded line 44" From AN365 restrictor fitting to Mainfold (PHT Aircraft hose) 2) Nylon adapter 1/8" to 1/4" hose from Manifold to Dynon map sensor 3) 1/4" Fuel line from Nylon adapter to Dynon MAP sensor 4) 1/8" MIP to 1/8" Tube for P-MAGS 5) 1/8" Tube Nylon Tee fitting
