Brief Description: Starter Cable Fabrication and Installation
Crimped the battery side lug for the starter cable and ran the wire through the attach points. Measured, clocked and cut the wire. Removed wire, crimped and installed heat shrink tubing. Reinstalled, torqued bolts and reapplied torque seal. Also installed the two diodes that protect the battery and starter contactor (see Blue and yellow heat shrink wires.
Ordered a few more insulation boots for the #2 starter wire to completely finish the job.
