Eds Vans RV-6A/7A Web Site
Date:  11-23-2012
Number of Hours:  0.00
Brief Description:  Canopy Release Bearing Block, Fabrication, 1
This Canopy Release Bearing Block comes square with one hole in it to receive the Canopy Release Shaft. It needs to be shaped and drilled as per plans.
Here you can see I used my trusted “Bearing Block Table Saw Clamp” to cut the corners off with precession.
Bearing Block Clamped in Jig.
Perfect Precise Cuts.
