Brief Description: Prime leading edge ribs, skins and joint-plates.
Before priming the inside of the skins, ( I only do the edges and rivet lines) I masked off a section around the landing light. This section will be aluminated by the landing light and may provide additional reflected light from the shinny skin. I'm not priming the landing light bracket either. When you look inside my landing light from the outside through the lens, you will see reflective skin and bracket, no primmer or paint. I think this will look cool as well. I've seen others with primer or paint and I think raw reflective skin and bracket will look very good.
