These plate-nuts will hold the landing light bracket. I drilled all the holes now but will attach the nut-plates after the ribs are primed.
I did the usual thing of drilling a hole for the plate-nut the same size as the #6 screw shaft. This helps locating the plate-nut mounting holes. Then enlarge the hole to allow some offset between the plate-nut threads and rib hole..
