Brief Description: Tank inboard bay showing flaired tube ends.
Here is the tank inboard bay showing the flaired tube ends for the vent and fuel return. The end rib is not yet installed but is next to be done.
Notice the capacitance wire has been cut. Yep, I'm doing it my way. I did this for easy installation. The other end of the wire is connected to the BNC connector that is allready installed on the end rib. Later, after I install the end rib I'll crimp a connector in there.
