Before priming I need to drill holes in the forward cabin cover plate that anchors the fuel valve and manual trim cable. I’ve decided to just go with the Vans supplies fuel valve. Why? I’m in the mode of not spending money for upgrades. 5/16” hole for fuel valve shaft and two ¼” hole for the fuel valve anchor bolts. I just stepped drilled them on the drill press.
