Eds Vans RV-6A/7A Web Site
Date:  8-29-2009
Number of Hours:  0.00
Brief Description:  Trim rudder pedal center brace.
I trimmed 2 1/8" of the angle to clear the firewall pop out thing. The cut you see in image 1 was a temporary cut just to get it mounted. After it was mounted and drilled I was able to measure the exact amount that needed to be trimmed. I didn't forget to put a nice radius at the intersection of the cuts.
I then trimmed 1 3/8" from the aft end. Notice I also trimmed a bit from the bottom.
