Brief Description: Roll Bar - Locate and drill the top 631E joint pla
The plans have you drill this plate from the outside even though it will ultimately live inside the roll bar channel. I simply clamped the plate a shown and drilled away. Again, study DWG 39 that shows that this plate is not located centered in the vertical direction. It’s moved downward just like the rear plate.
