Brief Description: Roll Bar - Match drill straps to top channels.
With the center straps located in a previous session, it was assured that the top channels would clamp down on top of the bottom channels with a perfect 1 ½” width. Of course I used the wood spacer blocks again. Now, simply match drill the strap using the previously drilled top channel flange as a drill guide. Easy, fast.
