Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Setup face plate to machine the ID's of Dist Base
Use live center to initially locate distributor base to the face plate and set clamps up.
Indicated in and tightened, double check, triple check.
I will line bore this end for .0015 press fit. There is not quite as much meat here as on the other end.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
