Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Make shaft to press out bushing from distributor
Turned shaft down on center, sneaking up on dimension because it was hard to measure.
Once the OD was established a pilot to the bushing ID was turned on the end.
Cut tube to support distributor near bushing before pressing out the bushing.
Turn od so it just fits
Add pilot for bushing ID
Press it out
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
