Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Turn down shaft to add bushing for rotor cam
Chucked up the distributor shaft and turned down the endso it can be bushed to take up the clearance.
Drilled reamed and cut bushing material to press on the shaft.
Turned down bushing on the shaft for proper clearance.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
