Both outer nose edges have a little gap, so filled with dry micro. This will also give me the ability to fill around the hinge pin tab, so it will end up being "recessed" when sanded back. At least that's the plan.
Dry micro fill
Upper cowl protected with duct tape so the epoxy will only stick to lower cow.
