Larry Winger's 601XL Project
Date:  8-6-2012
Number of Hours:  2.25
Brief Description:  Wired co-pilot side D-sub connector for stick grip
I decided to go to the other side of the airplane and try something different. As it turns out, I'm going to start over the and pilot's side and do it this way. I just slid a big heat shrink tube over a 6 in length of exposed wires and pushed it up over the blue main insulation. This gave me plenty of room to work, and I was able to make, insulate and secure my connections in record time. Everything tested out perfectly. I slow and don't always get the right approach the first time, but I'm persistent. In the end, I guess that's what counts.
The inside look
The inside look
Showing heat shrink wrap on long wire bundle
