Brief Description: Completed stick grip wiring D sub connectors
I completed the wiring of the D sub connectors tonight and answered the question of routing. The primary routing hardware is a #12 Adel clamp through an existing hole in the 6-B-6-4 upper engine mount fitting & BRS attachment. Eventually I will probably velcro the connectors to the left side panel to prevent movement and vibration. In a future session I'll also secure the blue cables across the firewall and around the center support channel. 8/8/2012: All circuits tested positive and applied Velcro.
