Greg's RV-12 Classic N719VA
RV-12
replaced valve cover bolt
Received the new valve cover bolts and replaced the one on the #3 cylinder. Torqued to 90in-lbs just fine.
Removed some oil from the tank because it was overfilled.
Fabricated two tubes for the carb sync arrangement.
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
