Greg's RV-12 Classic N719VA
Date:  6-13-2022
Number of Hours:  2.25
Brief Description:  check engine lifters
Checked the valve lifters to see if they are filled with oil per Rotax oil purge instructions. They are firm with no movement. When replacing the #3 cylinder head cover the bolt broke. Luckily I was able to easily remove the bolt because a thread was still holding. Ordered two new bolts from Leading Edge Airfoils.
