Greg's RV-12 Classic N719VA
Date:  6-3-2020
Number of Hours:  1.50
Manual Reference:  32-14
Brief Description:  connect aft stabilator control cables
Manual 32-14 steps 1 & partial 2, connect the aft stabilator control cables to the forward cables. Did not put in the locking clips. Coiled the cables in the back of the fuselage. Stabilator will be attached later and the cables will be installed further at that time.
Secured all other cables and wires in the back of the fuselage so they will not be in the way for attaching the tailcone.
Moved the hose clamp around the fuel lines near the fuel pump in the aft under the baggage area because the right flaperon push rod would touch it in the extreme position.
