Greg's RV-12 Classic N719VA
RV-12
redo left cowl hinge
Manual 23-08, redo left cowl hinge. I discovered that I used the incorrect hinge material (P2 not P3) for the left hinge. Drilled out rivets, fabricated left hinge with P3 hinge, match drilled and riveted. Used existing spacer which was okay.
RV-12 Home
2006
Aircraft flight
256
319
388
Flaperon
Flight Controls
Fuel Tank
465
Lighting
Manual prints
Notifications and le
RV-12 Expo
Service Bulletin kit
Shop work
Tech advisor check
211
