This morning I started the installation of the centre console, basically the L angels are cut to length and installed and the console sides are then back drilled to the L angles, sounds simple and it is, but it does take a fair amount of time. With both sides complete, I then installed the console cover. This entire assembly really ties the front spar and rear seat back together to form a very strong structure.
Left side L angles and centre console side drilled to #20
Right side L angles and centre console side in the process of being drilled to #20
