More leveling tonight, this time setting the height of the longerons to 497mm just behind the main gear channel by inserting two boards again cut to a height that is determined by the fuse assembly, this took a couple of goes to get right. After this I drilled the rear spar attach brackets to the rear spar support and then located, marked and made the cutout on the left side of the fuse. Right side still to go. Sad thing is I am going away with work for two weeks, so this is where things will stop until I get back.
More leveling of the fuse, set the height at 497mm
