I had the day off work today with what felt like the onset of the flu, I finally crawled out of bed around 12:30 and sorted myself out, by 2 pm I was feeling fairly human so I decided to turn the heater on in the garage and install the landing gear supports. With all the skins being pre-drilled this was very easy, but time consuming at the same time. I can only put this down to the fact that I was not firing on all cylinders
Left landing gear bracket installed
Vertical L angle supports installed for landing gear
Right landing gear bracket and vertical supports installed
