This was quite tedious to do, but again its another job over with, the fuse is again level and set at the correct angles, so now I can move onto mounting to undercarridge support brackets. I have moved the work bench against the wall of the garage so that I at least have a work area, the other option was to disassemble, which was not very enticing.
Fuselage on saw horses
New position for the work bench against the garage wall
