Marked all elevator rib center lines and inserted inside skin, lined up front holes of the elevator with ribs and back drilled. Clecoed front of ribs in place and lined up top skin with rib center lines and back drilled. Turned elevator over and back drilled skin to bottom of ribs. Marked elevator hinge centre line and inserted into elevator skin, back drilled and clecoed in place.
