Brief Description: Underside of wing final coat painted
After the terrible weather of the last week, this morning has actually turned out OK, I fired up the heater in the spray booth the reduce the humidity a little and prepared the wing for its final coat of white on the bottom rear section by giving it a wipte down with Prepsol. The painting has turned out quite good and I only managed to attract 4 insects, so a little touch up with the paintbrush should do the trick to hide the marks after I scrape away the bodies once the paint is dry...
Outboard view, rear section with final coat of white
