I put in a major effort tonight given it was relatively warm, and fired up the heater as well, the end result is pretty good, although I had a minor disaster on the left rear of the fuselage when pulling the tape off, it appears that some of the etch primer on the rear section did not take very well and instead of just removing the tape I removed a line of paint. Just what I need, some more rubbing back and attemping to repsray the white section between the yellow and blue line. Oh well its a learning experience.
Masked up and first coat applied
Right view, its not as dark as it appears in the photo
