I am adding a Royal Blue stripe to give the paint scheme a little more contrast, the stripe will of course be between the two Blue masking tape lines, it was to cold to cover the fuselage with paper tonight so I'll have a shot at getting that done tomorrow. The spacing for no particular reason than I think it should look good, is from the bottom of the Yellow, down 60mm to create a White stripe, followed by a 60mm Royal Blue stripe; I will continue this onto the cowl when I have finished preparing it for paint.
