Eddie's Zodiac XL Project
Date:  6-15-2007
Number of Hours:  3.50
Brief Description:  Finished front spat installation
I finished the wheel spat installation by first filling the holes I had drilled for thr mounting brackets with some resin miced with chopped strand fibreglass. Once this had cured I re-drilled the holes and then mounted the spats, the mounting system is really quite solid, and I think once they are painted they will look better, or at least I hope they do.
Right side holes drilled for mounting brackets and screws installed
Left side holes drilled for mounting brackets and screws installed
Head on view, I am hoping that after the spats are patched and painted that they will look much better
