Brief Description: Started wiring the Main and Instrument Bus
After buying a decent crimping tool, wire and terminals etc. I started wiring the circuit breakers and the Main and Instrument buses. Its been too humid to paint / prime so I thought I might as well do this job, its pretty tedious standing next to the plane doing this and my upper back is smarting, but the first part is now done, I just need to wrie up the engine instruments and other avionics when I get a chance. I also managed to find another solinoid indentical to the started motor solinoid supplied by Jabiru for $8.00. I have mounted this inside the front fuse and it will connect the battery power to the two power buses, activation is of course via the master switch.
