Eddie's Zodiac XL Project
Date: 12-24-2006
Number of Hours: 3.00
Brief Description: Engine gauges and fuses
This afternoon I laid out and cut and drilled the holes for the engine instruments and fuses, the hole next to the cylinder head temperature gauge is going to be for left and right exhaust gas temperature, I am planning on monitoring the two rear exhaust gas temperatures and probably the two rear cylinders for temperature. There was a suggestion from one of the instructors in our club, that all the cylinders be monitored for temperature, which is still a possibilty if I install a rotary swich to select the different cylinders. The bottom right fuse (40 amp) will move from there to the pilots side and be replaced by a hand throttle. I am also going to move the radio (marked in black pen) up a little more and mount the carbie heat and choke cables just above the center console in the main panel along with the flap switch and fuel pump switch. The layout for the left hand panel will be top row left to right, Air Speed indicator, Tacho, Altimeter, bottom row left to right, Turn and Bank, Clock (no hole yet) and Vertical Speed indicator.
Holes cut for instruments and fuses, and a trial fitting
The business end
