Eddie's Zodiac XL Project
Date: 12-12-2006
Number of Hours: 1.00
Brief Description: Installed Air Mixer box
In preparation for mounting the engine, I have installed the air mixer box, as I suspected, it would be a pain to install once the engine is mounted, the only thing still left to do on the airbox is install the air outlet duct that feeds the carbie, sadly Jabiru don't install this, and there is really only one place it can go, job for tomorrow night. The other annoyance is that the air box occupies nearly the whole left side of the firewall, I'll have to try and make sure I use any free space here well. I have also decided to use a combination of floating nut plates and speed nuts to make the entire forward top turtle deck removable so that I have really good access to the wiring and instruments. Here's hoping it works.
Air filter / hot air mixer box mounted on firewall
Head on view, I still need to install the air outlet to feed the carbie
A temporary re-installation of the instrument panel and side flashing, less scratches this way
