I spoke with Doug at Jabiru today about the cowls, oil access hatch (missing) and air box. Doug is organising to send down the smaller air box developed by Jabiru USA, he was hoping that the standard air bix would fit. Also the new cowl assembly hardware (hinges etc.) and instructions for assembly, this cowl goes together using piano hinges, similar idea to that used by the RV people and finally the missing oil filler access hatch door and associated bits. I also have on back order with Jabiru, the prop, magnito switches and the oil cooler and its associated assemblies.
Engine mount load test certification sheet
Right view bottom cowl is a good fit
Best I could do for a head on shot, its getting a little cramped in the garage
