The engine mount pretty much fitted the firewall, just needed to move the two corner support brackets to the top of the nose gear bushing support channel. Note the airbox does not fit, it needs to be about 60mm shorted length wise, will have to talk to Jabiru tomorrow about this.
The angle bracket at the top left used to be underneath, but as you can see this would not have worked
Same for this side, L angle move to the top
Air box is too large, needs to be about 60mm shorter
