Eddie's Zodiac XL Project
Zodiac 601 XL
Nose gear stop plate
The plate comes as a square section that needs to be rounded to a diameter of 65mm and two holes drilled at 10mm from the center.
Front gear stop plate drilled and rounded
RV-7 Home
Zodiac 601 XL Home
2696
Ailerons
Baggage Tray
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
Left Wing
142
Mounting Horizontal
Rear turtle deck
Test flying
Undercarriage
Undercarridge
Upgrade
Upholstery
Weight and Balance
Wheels and brakes
554
