Eddie's Zodiac XL Project
Zodiac 601 XL
Mounted Horizontal Stab
I'll add a story and description of making the cut out templates later, I'm just a little to tired at present.
Right side view looking back, a 2mm gap has been left all the way around to fit a rubber trim strip
Left side view looking back, a 2mm gap has been left all the way around to fit a rubber trim strip
RIght side view, mounting brackets drilled out to #20
RV-7 Home
Zodiac 601 XL Home
2696
Ailerons
Baggage Tray
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
Left Wing
142
Mounting Horizontal
Rear turtle deck
Test flying
Undercarriage
Undercarridge
Upgrade
Upholstery
Weight and Balance
Wheels and brakes
554
