Well it had to be dome sometime, I pulled the baggage tray supports out along with the seat back and deburred and dimpled all the parts before coating with Cortec. Once the parts were dry I re-installing and pop riveted everything in place. It was a long process, but its done and I managed to retrieve heaps of cleco's. I also while I had the area apart drilled the holes that allow the elevator and rudder cables to exit the seat back and rear flap torque tube support channel. No pictures today as it looks very much the same.
