I didn't think I'd get anything done tonight as I came home tired and unenthusiastic. Anyway after I got dinner going I went out to the garage and achieved a reasonable amount. I installed the last rear L angle for the baggage floor, removed it again and marked the aircraft center line. Installed the middle C channel stiffener and back drilled and clecoed. Installed the floor yet again and marked the rivet center line from the C channel onto the baggage floor. I'll drill the baggage floor to this C channel tomorrow night. Last but not least, I checked that the fuse is still square between the top former and the fuselage floor using a plumbob. Have I mentioned that this is the least enjoyable part of this project so far, I am fast getting to dislike the number of times the baggage floor has to be placed into and pulled out of the fuse.
Installed the front floor stiffener, its the middle top C channel in this image
Rear L angles back drilled and clecoed to the baggage floor
Plumbob used to check for square between the top former and the fuselage floor
