Eddie's Zodiac XL Project
Date:  5-28-2006
Number of Hours:  1.00
Brief Description:  Rear access door
Before I finished for the day I installed the hinge for the door, I sware the hinge was cut by a butcher, I had to clean it up before I could get it to rotate without binding. I then slid the hinge between the fuse skin and back drilled, I then used the hinge as a template to back drill the door, once both sides had been drilled I dimpled the hinge and the door. The door still needs its corners radiused, as well as fitting the floating nut plates to the fuse, maybe a job for tomorrow night. The rear formers will then be pop riveted in place in preparation for fitting the side skins.
Rear access door clecoed to the hinge
View of the door looking aft.
