Brief Description: Fitted finger strainer support bracket and cover
After making the support bracket for finger strainer cover (I am going for the flush finish), I attached the floating nut plates, I have one nut plate that has poped off its rivet on one side so I need to go back and fix this, I obviously didn't squeeze it enough and when I was putting pressure on one of the screws that holds the cover in place it poped off.
Finger strainer support backet pop riveted in place and cover attached
