Brief Description: Installed muffler and exhaust pipe
After yesterdays efforts, I re-intalled the muffler with Anne-Maries help to ensure that the clearance between the cowl and the firewall was adequate. I am pleased with the end result, the exhaust pipe just protrudes below the cowl. I hope this is a good thing and will not cause undue drag, but I'll check it out before committing to getting the pipe tig welded into place. I also glued the rubber baffels in place with 5 minute aryldite. Now back to designing a set of dual throttle arms, I'll post some pictures soon.
I ended up getting lucky and there is good seperation between the cowl and the firewall
